GF3 Ti200 problem with Unreal Tournament
Mattlock
492
Just bought the card. Quake III runs great but when I start up UT, the sounds are "gurgled" and as soon as the main screen pops up the video freezes and system locks....
any thoughts.
thanks,
Mattlock
Flatbroke
721
My sounds are ok, but get freezes and or reboots with same card and UT. I thought this was a good card, disappointed with it, problems at default settings.
backbreaker
Are you running opengl or direct3d? I had the same promblem under direct3d. Switch to opengl and everything works fine.
RgrPark
1,086
make sure you load up the s3tc textures from the second cd... you can take use it under opengl...looks great and no hit on fps...
this is an old link
just do a search on "s3tc enable unreal tournament opengl geforce"
vss1980
2,944
I think he means the 2nd cd that comes with unreal tournament.
That has compressed textures on it.
