GF2Ti and W98SE problems.. help please!
Priit
1,337
I'm testing GF2Ti video card in my machine but can't get side-band adressing and fast writes to work . I installed latest Nvidia drivers and AMD AGP driver (mobo is ABIT KG7) but WCPUID and Sandra are still showing that SBA and FW are disabled (they show that they are supported thougt. AGP operates at 4X mode). I enabled FW from BIOS and SBA worked with another video card (Matrox G450) without problems. What gives? Is there any kind of utilites that would allowme to enable/disable those features? I don't care much about fast writes, but isn't missing SBA decrease performance considerably? Thanks for help!
HardWareXpert
Dont bother and there really is no point as you would'nt notice a performance increase anyway, it can course unstablity more often than not.
Priit
1,337
OK, I downloaded riva tuner. Fields, where I could turn SBA and FW on, are grayed out so I can't change them. I couldn't find any AGP tweaking abilities from powerstrip. Thanks guys, but me still unhappy :(
