GF2 Pro 32 or 64MB?
Desslok
Will I see a difference with the extra ram? I just play Team Fortress,Quake and Tribes 2(32 bit color and 1024x768). I want a card that can age well so I can hold out for a year or two. So that rules out the KyroII because it has no T&L.
Thank you in advance.
Chris
from what i have understood from friends of mine that are more knowlegable than me, the geforce2 core is unable to utilize more than 32megs of ram. however, i suggest you check overclocking/review sites to get a better idea. www.hardocp.com, tweak3d.com etc.
um, why dont you just check out Anandtech's reviews? they're just as good, if not better then the other site's reviews
