getting the fan speed set
Markfw
May 16, 2002
27,427
16,293
Help ! I think my new card is overheating, as after a whole the PPD goes down, the the system locks up, and says nv_disp is the problem. Same system with a 8800 GT was stable, changed the video to 9800 GTX, and it does this.
What other tools are there ?
Markfw
May 16, 2002
27,427
16,293
Only works on an evga card, this is an MSI card.
Thanks anyway
jonesthewine
689
can you put the 8800GT back in the system? what drivers are you using? try reverting back to some 178 series if you're using 180s and see what happens. did the MSI install disk have any utilities on it?
Markfw
May 16, 2002
27,427
16,293
I tried utilities. I am on 178, tied 180s' and no change. If I try to change and apply using nvidia utility, it says "changes are illegal and won't ne saved" or some crap like that. rivituner does NOT hve the same menu as my other cards, and thats where the fan speed controller is.
I need another alternative.
biodoc
6,350
2,243
What about a manual control rheostat like this
On second thought, these are only for 2 wire case fans. Your VGA fan probably has 3 wires?
Can you splice and lengthen the wires and plug it into a 3-wire fan control receptacle on your MB?
I suspect MSI disabled fan control in the bios on that card.:(
Insidious
7,649
It's normal to see different options available for different cards using RivaTuner but loosing fan control on 178.xx series video drivers is NOT normal.
suggestions:
uninstall RivaTuner and the NVidia tweaker you have tried. (tell it you do NOT want to keep existing profiles)
Re-install the latest (probably the same as you are presently using) version of RivaTuner
Be sure to check in both the low level and the driver level tweak sections of the RivaTuner menus.
Good Luck.
(MSI, DFI, XFX, BFG, PNY, Ballistix) <-- never again to land in my PC :evil:
