Getting parts to upgrade my PC into a HTPC
airhendrix13
427
I'm not sure what category this exactly falls under, so I just put it here.
Alright, so basically what I want is the ability to watch HD movies, play HD games, and watch non-HD cable on my 24" LCD monitor. The reason I want to be able to do all of this on an LCD monitor is because I will be moving into a dorm soon, and having one monitor that can do it all would save space.
Is there an input card I need to put in my PC for this, or is there something external I can buy?
I'm hoping to get something that will have somewhere around 2 HDMI ports, 2 sets of component inputs, and some VGA ports as well. (for Blu-ray / DVD / HD DVD / Consoles)
I'm not sure if something like this exists, so if someone could point me in the right direction that would be great.
Thanks
MegaVovaN
4,131
No such thing as HD games... ;)
Buy HD TV Tuner to be able to watch cable on your PC.
The same TV tuner may be able to play non-HD cable, else buy non-HD tv tuner.
For HD/BluRay, buy an HD/Bluray drive from LG (kinda like DVD burner but can play both HD and bluray...costs $300 I think).
Perhaps console has DVI output? In that case just connect monitor directly to it.
I do not know if device like KVM exists (which would allow you to connect your console and computer to it and switch output from either one with a flip of a button - FLIP, monitor shows console, FLIP - monitor shows PC output).
airhendrix13
427
Hi MegaVovaN,
Instead of spending $300 on a new drive, I was thinking something more along the lines of an input box that I could connect the outputs of my DVD, HD DVD, and Blu-ray player that I already have and connect that into my monitor.
Anything out there like that?
Thanks again.
secretanchitman
9,352
23
Originally posted by: airhendrix13
Hi MegaVovaN,
Thanks again.
the $300 player is sata and reads both high def format...so all you need is to set your monitor to the pc input (hopefully its dvi/hdmi!) and you're set.
DSF
4,902
Hi MegaVovaN,
Thanks again.
If I understand correctly, he already has the necessary hi-def players. He doesn't want to spend $300 on a redundant drive, he just wants to connect his existing player straight to his monitor.
airhendrix13
427
Thanks for the responses guys.
Yes, I already have the players and stuff. Basically I want to be able to view HD movies and stuff with the blu-ray / HD-DVD players I already have, but monitors don't have as many input connections as TV's, so I need to something to resolve this issue.
I found this:
http://www.newegg.com/Product/...x?Item=N82E16824113012
It has quite a bit of ports, but can I switch inputs VIA the monitor like on a TV or can I only have 1 thing plugged in and running at once?
Thanks again,
Ryan
