- Jun 30, 2004
- 16,743
- 2,097
- 126
I've grown concerned about my backup options for a WHS-2011 server using Stable-Bit Drive-Pool.
In order to back up the server with either the built-in Windows Backup feature or Acronis True-Image 2014, I must back up the duplicated folders from each and every drive in the pool. In doing this, the backup files still contain the duplication -- an unnecessary use of backup storage space.
Further web-search investigation points to the use of the RoboCopy feature first included with Win 2003, built-in to Win 7 and WHS-2011. RoboCopy is sort of an enhanced XCopy utility that would run in the command window, but you can write scripts for it. I suspect that it's even possible to schedule execution of the scripts, and it works like incremental backup.
MSDN first produced a GUI for RoboCopy entitled RoboCopy GUI. It was then updated or replaced by a GUI entitled RichCopy.
Now that I've installed it, I discover that the program's link to the Help file doesn't work, but you can access Help by simply clicking on the Help file and opening it separately.
Is there something I can do to assure that the Help is accessible through the RichCopy program -- as it is supposed to be?
