- Aug 3, 2004
- 29
- 0
- 0
OK, so I'm getting a new PC...I am experienced with computers but more so with software, and I have never built my own computer before. I am working with a roughly $1500 budget. I've picked a case (a nice-looking Raidmax with 420W PSU and 3 fans) and video card (Radeon 9800 Pro 128 MB) and so I'm up to $249 so far. This PC is for college as well as gaming, and for gaming, if I can run Battlefield 2 at 1280x1024 with moderate graphics settings and 45 FPS I will be more than happy. I think I'm going to get a 19" LCD monitor because that will just be sweet. I would be fine with 17" though if I was nearing my budget.
The first thing I have to do is decide if I'm going to go with AMD or Intel. I have never used AMD before but the general advice I have gotten is towards it. However it has been mixed, and even among the AMD-proponents it is mixed...one person says to go with an Athlon XP 2600 because it will become unusable around the same time as any other chip I buy now, and another person says to get a 64 bit processor. Honestly I think this will be the most expensive thing to get the best of, and if I get a 2800 or something I can probably upgrade it in a year if I need to for $100 or so. Of course this affects my motherboard choice as well. The only thing I know right now is that I will probably get an nForce so I don't have to get a sound card.
I want to get 1GB of DDR, 2x512. I guess I can just pick this based on specs...but how do I know if it is compatible with my motherboard? Same goes for hard drive, I am looking at either 80 or 120GB, but I don't know how to know if it will be compatible with everything else - I think this is based on whether I get SATA or IDE or SCSI but I don't know how to tell which I need for which mobo.
So basically, I guess I am asking for advice on AMD vs. Intel as well as on Athlon XP vs. Athlon 64...leaning towards Athlon XP right now but interested in people's advice. Also, and I guess this is my main question: How do I know if my memory and hard drive will be compatible with my mobo/CPU? And are there any other compatibility issues I need to check?
Thanks so much for any help.
