Getting a Dos bottable floppy when using XP or 2000
elmeric
Hi there,
it might be a very simple question but the requirement for a bios update of my motherboard , is to use a dos bootable disk on which one needs to download the new bios a flasher. Unfortunately, I only have access to Windows XP and windows 2000. How can I make a bootable disk from these OS?
Thanks in advance
Eric
Eric, put the floppy in the xp system then go into my computer & right click the floppy & you'll get an option to make a
ms dos boot disk.
Thanks Bacillus for the quick answer,
Very simple indeed
Gunbuster,
I admit it was the wrong forum, it should have been in the OS section but your answer was not too constructive
Thanks anyway
Eric
Originally posted by: Gunbuster
Welcome to Anandtech
Wrong forum section
Bootdisk dot com
what he meant was
hello and welcome to anandtech i see its your first post😛
when the mods see this they will lock this thread since its in the wrong forum or maybe just move it if your lucky so i better answer fast
go to www.bootdisk.com they have a whole download section for all the os's boot disk files,simply download the flavor you need and unzip it to a floppy,bootdisk ala quick😉
but since the mods are being kind today i thought i would aid gunbuster in getting the meaning across😛
welcome to anandtech elmeric its great to have you with us😎
