gets() in a void function -- C help
trilobyte
60
How come gets() works in my main, but if I call it in a void function (example: void change(char * string) ) it won't let me input from the keyboard?
lets say I have this
*psuedo-code btw
gets(string);
now gets(string) SHOULD give me a keyboard-input prompt right? It doesn't though. It will if I did the gets(string) in the MAIN...but in a void function..it simply assigns string to "" and exits. Can anyone tell my why and how may I go about fixing this? BTW this is for a line, not a string (so scanf won't work).
singh
1,449
You mean this doesn't work:
void Do(char* strInput)
gets(strInput);
printf("%s\n", strInput);
int main()
char strInput[100] = {0};
Do(strInput);
return 0;
trilobyte
60
exactly, that doesn't work
on the printf in the do function, it'll just give me an extra line. it won't let me input any text.
*edit: ok...wtf. that little program you posted works...but in function in this program i'm writing...it doesn't...hrm...i'm going to have to really look now...
singh
1,449
Are you sure? It worked perfectly when I tried it.
trilobyte
60
hrm, apparently it's something in my switch statement...oh well thanks anyway. gunna have to track this bug down
trilobyte
60
Ah I think I got it now. I wasn't flushing the buffer properly after past keyboard inputs from other function calls ;)
