getJSON issue with complex URLs
TechBoyJK
16,699
60
I'm trying to get an AJAX function working, and it otherwise works except for when one of the included arguments is a string with a bunch of special characters (like a pw).
Code:
$.getJSON("http://company.com/access.cfc?method=checkUserCredentials&userID="+ #session.myID# + "&lastname=" + lastName + "&firstname=" + firstName+ "&email=" + email + "&password=" + password,function(checkUserCredentialsResults)
This works fine if the password doesn't contain any prohibition/special characters.
For instance.. 'test123' works fine, but 'test!@#456' gets truncated to 'test!@'
Do I need to encode this url?
Crusty
12,684
You need to encode every piece of data you put into a URL query string. That's what the definition of a URL is. I'm assuming that this sets up some sort of session on the server so I think you really should be using a POST request here anyways.
beginner99
5,320
1,768
Code:
I just hope this application is not facing the internet...or its https.
http://stackoverflow.com/questions/332872/how-to-encode-a-url-in-javascript
Dratickon
21
I'd also recommend using POST rather than GET. Either way, jQuery will handle the encoding if you let it build the request itself.
Code:
$.POST(
'http://company.com/access.cfc',
method : 'checkUserCredentials',
userID : '#session.myID#',
lastname : lastName,
firstname : firstName,
email : email,
password : password,
[I]your callback,[/I]
'json'
Using getJSON works just as well, but you just need to change how you're feeding it the variables:
Code:
$.getJSON(
email : email,
[I]your callback[/I]
Leros
21,867
7
Alternatively, if you want to be manual, you can call encodeURIComponent().
Code:
var url = "http://company.com/access.cfc?method=checkUserCredentials" +
    "&userID=" + encodeURIComponent(#session.myID#) +
    "&lastname=" + encodeURIComponent(lastName) +
    "&firstname=" + encodeURIComponent(firstName) +
    "&email=" + encodeURIComponent(email) +
    "&password=" + encodeURIComponent(password);
$.getJSON(url ,function(checkUserCredentialsResults);
