Question Get serial number using software for Gainward GeForce RTX 3060 Ghost 12GB or Palit RTX 3060 Dual-LHR 12GB or for any RTX 3060 / RTX 30 series?
regularname
26
Hi there! I'm looking to buy a second hand GPU, an RTX 3060, with a warranty, and the models above are for sale. I'm trying to check if those cards have embedded in themselves the serial number as software, so I can check it with the serial number on the label, to make sure they match each other. I can then check if they match the serial number on the invoice. If they don't match then it means something is shady with the GPU and I won't buy it.
I know the label can be faked, that's why I'm looking to get to see the serial number as software. Actually, I suppose the serial number as software can be faked as well, but I think there are low chances for someone to be that skilled.
I know the invoice and the warranty can be faked as well, but I think I'm close to coming up with an idea that will eliminate the risk of those two being faked.
So far I tried to get the SN for GeForce 9500 GT and GeForce GTX 1660, under Windows 10 x64, by using this command in the command prompt:
Code:
nvidia-smi.exe --format=csv --query-gpu=name,serial
I had to locate nvidia-smi.exe, to do that very easily I used Everything.
Getting these results:
Code:
name, serial
GeForce 9500 GT, [Not Supported]
Code:
name, serial
GeForce GTX 1660, [Not Supported]
I read this article, but the SN I got wouldn't match.
I know some cards offer this info, one of them is GeForce GTX 1080, as seen here. But this was done under Linux, so I don't know if it would work with Windows.
On Linux darkseid4nk used this command to get the serial number:
Code:
nvarr=($(nvidia-smi -L | awk ' {gsub(/:/, ""); print $2}')); for i in "${nvarr[@]}"; do nvidia-smi -i $i -q | grep -E 'Minor Number|Product Name|Product Brand|Serial'; done
Getting a result as such:
Code:
    Product Name                    : GeForce GTX 1080
    Product Brand                   : GeForce
    Serial Number                   : 0413xxxxxxxxx
    Minor Number                    : 1
royce came with an alternative code in the same thread:
Code:
#!/bin/bash
    echo " $i: -----------------------------------------------"
    nvidia-smi -i $i -q | grep -E 'Product Name|Serial|Bus Id|UUID|  Power Limit|Default Power Limit|GPU Part|Image Version|Link Width|(Max|Current).*:.*[0-9]x$|PCIe Generation|  (Max|Current)  .*: [0-9]$'
done
echo "-----------------------------------------------"
Can someone please help me check the serial number using the methods above, either using Windows or Linux (I didn't find how to do it for MacOS), and also check if that serial number matches the one on the label attached to the GPU?
If you used different methods to get it, please let me know.
Thank you!
KompuKare
1,228
1,597
This all implies that each ASIC has set off fuses which can be set to be a serial number.
CPUs certainly do (otherwise TPM etc. could not work).
And NICs of course famously have that (MAC addresses).
Unsure whether GPUs have this, although this come up sometimes with people worried that some online game has banned a user by the hardware ID /serial of the GPU.
Reactions: regularname
regularname
26
Thank you for the input!
As far as I have read, when it comes to GPUs, online games ban players based on the UUID of the GPU, which can be seen among the lines by using this command for Nvidia:
Code:
nvidia-smi.exe -q
MrTeal
3,919
2,708
The AIB partner might have data that links GPU UUID to their serial number, but translating that to the serial number for warranty purposes won't be obvious and would depend on the AIB. For my EVGA 3080 FTW3, there's nothing shown on HWinfo64 or their Precision X1 overclocking tool. In fact with the 10 series there was a Precision X1 update where you actually had to get the serial number off the label or box and enter it to use EVGA's own software, it had no way to read it from the card.
FE models might have more luck, but there is no 3060 FE.
