Geometry problems on Samsung 700NF.
Imported
14,679
23
My geometry on this monitor is bad and I can't seem to adjust it correctly. If anyone has this monitor, could you post your geometry settings? Also, is there a program that could help with the geometry? Thanks.
GT578
721
Most people that I see posting messages here have the 900NF...and that's what I have too. Just play with the settings...i had to keep adjusting for like 2 days before I was totally satisfied......its not perfect...but then again....none of these FDtron or NF based monitors have a perfect picture....there is always some geometry probs.
Imported
14,679
23
I'll keep trying. But can 900NF settings be used on the 700NF? Just wondering since there are in the same series and stuff.
heng1028
1,792
I have problems with setting the screen with the 700NF.
The screen distort a little bit but i couldn't get it fix. :(
heng1028
1,792
and 1 more thing the 700NF there are 2 tiny lines in the screen. Is that a defect or that is the way it should be?? I was told that the something 'grill' technology. Is that true??
duragezic
11,234
4
Yeah every Apeture Grille monitor has the two lines across the screen.
I have a 900NF. What settings are you looking for?
