Generic scanner power cable.
Mahaguru
326
I have an HP scanner, it is missing a power cable. This isn't some special power cable or anything, just a regular one which is small on one end (the scanner end) and regular size on the other end.
What is this kind of power cable called, and where do I find one? I couldn't find one at home depot, or walmart.
cprince
963
www.ebay.com the physical size of the connectors is only one of serveral factors. You also need to consider the voltage and amperage the scanner needs.
OdiN
Banned
Mar 1, 2000
16,430
If you can find out the voltage and amperage that the scanner needs, you should be able to get an adjustable wall wart from radio shack and accompanying connectors to fit your scanner.
mindless1
8,785
1,774
Make sure the Radio Shack supply is a regulated type, as the older Radio Shack adjustable supplies were unregulated and at typical (not yet scanning) low load would float to a significantly higher voltage. Also some adjustable supplies only go up to 12V while the scanner might run a little higher, 12V is commonly used by I have seen a few (non-HP) that used 15V.
By the original description of the cable as "regular" I would suspect it's a typical DC barrel connector, which comes in various sizes so the OD (outer diameter) and ID (inner diameter) will need to match, or a couple best-guess connector sizes might be bought and the right one soldered onto the PSU leads (observing correct polarity which is "often", but not guaranteed to be, outside ground and inside positive power).
Once the needed voltage is found, with a regulated supply the current can be fudged a little so long as it is enough. In other words I would expect a common 1A current, 1.5A at most, is sufficient for a typical scannner and actually scanner actual consumption is a bit less than that.
A few online electronics surplus 'sites may have what you need for example MPJA, BGMicro, AllElectronics, Electronic Goldmine, Excess-Solutions to name a few. As an example at BGMicro,
http://www.bgmicro.com/index.a...n=VIEWCATS&Category=99
you'd want the type they're calling switchers, not one with no mention of switching or regulated, and "probably" not one that is linear (regulated) because the linear type waste a lot of power, create more heat and linear is not needed for a scanner.
BGmicro also has a few sizes of the barrel connectors if the original connector is not right like these:
http://www.bgmicro.com/index.a...n=VIEWPROD&ProdID=9505
http://www.bgmicro.com/index.a...=VIEWPROD&ProdID=11124
Unfortunately BGMicro (and some others) don't describe their parts very well, these should be 5.5mm OD and the 2.1 or 2.5mm are ID measurements. These two sizes seem to be the most common barrel connectors used on most equipment but check yours... visually it can be hard to tell 2.1 from 2.5 ID unless you have a 2.1mm ID you know is 2.1 and it won't plug into the socket, but if you can tell it's 5.5mm OD then buying both is only 25/50 cents more.
If the scanner takes 12V a random suggestion would be the following then if you can't discriminate whether it's 2.5 or 2.1mm ID (and can that it's 5.5mm OD), also throw a 2.1mm ID connector as linked above into the order. This supply certainly is capable of more current than the scanner needs (I just don't know about the voltage) which is ok since it's regulated, and ok since at surplus pricing it isn't costing much if any more for that increased current capability.
http://www.bgmicro.com/index.a...=VIEWPROD&ProdID=12293
mindless1
8,785
1,774
What exactly do you mean by the above description, especially the part about "regular size on the other end"? Do you have the physical supply itself that plugs into the wall and you are needing only a cord to run between the supply and scanner? If so then my last post wasn't applicable. If you just need a *piece of twin conductor wire* with physical connectors on both ends, how easy it might be to find that might depend on if it's a common type of cable, otherwise you might have to make it yourself or find some leftover surplus or ebay, etc.
JackMDS
29,557
431
Mahaguru in order to save some time it would very nice of you to post the model number of the scanner and a little more about what the general None specific term Power Cable means.
Have a Happy New Year.
Mahaguru
326
Originally posted by: Aluvus
Would I be correct in guessing that it is similar to this?
Yes, it is similar to that.
The Scanner is a an HP C6270 and power requirements say 0.52 - 0.26 A.
