- May 19, 2000
- 600
- 0
- 0
I am somewhat considering a similar network setup. Although I'm not that technical, I can get around. But my questions really lie within the hardware involved.
I have a DLINK DI-624 and a Netgear MR-814 (Super G and Standard B, respectively). The DLINK is currently connected to the cable modem and has one computer directly connected and several wirelessly. I want to know several things:
1) what are these terms: acces point and bridge?
2) can i connect the netgear to the dlink via ethernet cable to have the netgear transmit wirelessly in another residence? (assume i have long enough cable)
3) can i connect the netgreat to the dlink via wireless to do the same as above?
4) is there hardware that simply allows for a wireless transmission (where i can connect to a switch port)?
thanks a bunch if you guys answer these questions!
-elf
-elf
