I'm trying to get a VPN setup and I need some help. I have two offices (A and B) that I need to connect such that they both appear to be on the same LAN for so that a user at either location can see fileservers and license servers from both sites. I also need to setup client - site A and client - site B connections.
Do I need to run an IPSEC VPN? SSL seems much easier but I don't know if I can use it with the FlexLM license server software I need to run. I am currently using Hamachi for client - site but it was a pain to get it working on the same PC as my license server (had to run two NICs) and I really don't want to continue using it. I'm not sure what kind of VPN it uses.
Do I really need to get one of the pay VPN clients or do the free versions work just as well?
What hardware would you recommend? I have access to and can change anything at either site. I'm currently looking at a couple of routers such as RV042 and FVS336G which seem as though they might do the job. I'm currently running a FIOS modem/router at one location but I imagine I can put it in some kind of passthrough mode.
Any suggestions or recommendations? And sites I need to read?
Oh and I have one more advanced question in case the above is too boring. Let's say I get a site to site VPN going. Is there any (easy) way to restrict certain users to only accessing one of the sites? Or should I just forgo the site to site stuff and use nothing but clients at each location?
edit: oh, let's say a dozen users total
