General SCSI Question (speed)
Keego
6,223
On my Adaptec 29160 card, I have a Seagate ST318406LW drive, it's speed is 160 (according to the seagate) but when I start the computer and the SCSI bios pops up, it says the model #, then after that it says 40. Is that what speed it's running at? Or is that just some random number on the end?
GoSharks
3,053
it is running at 40mb/s
are you using a proper lvd cable and active termination? check that the adapter is set to run at u160 in the bios, and also make sure that you have not jumpered the drive to be in SE mode, you want lvd.
dszd0g
1,226
It may be as simple as going into the Adaptec BIOS and changing the speed, but most likely not. Adaptec BIOSes generally detect the correct speed for that configuration.
GOSHARKS hit the possible issues on the head. Make sure you are using a good brand and quality LVD Ultra 160 or Ultra 320 cable (A.k.a Ultra3 or Fast-80 for Ultra 160 or Fast-160 for Ultra 320. SPI-3) and a good quality LVD active terminator.
Make sure it is plugged into the internal LVD SCSI connector and not the internal Ultra Wide connector (both 68-pin). And as GOSHARKS said, make sure that the drive is not jumpered in SE mode.
For optimal performance one should use the shortest possible cable that will reach.
Just cause I feel like it, general SCSI rules that don't apply to your problem:
Start with SCSI Id 0 for hard drives and go up. CD-ROMs and other devices should start at SCSI Id 6 and go down. If you have more than 7 devices other than the SCSI controller, put your boot HD on SCSI Id 0. Then start the rest of the HDs on SCSI Id 8 and go up to 15 from there.
The above will provide the optimal performance based on SCSI Id priorities, slower devices need a higher priority otherwise they will often fail to negotiate for the bus.
Avoid mixing cable types (generally mixes impedances) as it adds reflections (noise) to the bus.
The SCSI-2 specification states that no more than four devices may provide termination power (TERMPWR) and that the host adapter must provide termination power. I generally just let the host adapter provide termination power, but theoretically if you let the last device on each end of the bus provide TERMPWR you may increase the speed of the bus. SCA devices generally cannot provide TERMPWR. The more devices that provide TERMPWR the hotter the TERMPWR wire gets and the more current used (more power wasted). More than four devices providing TERMPWR may (and most likely will) cause excessive heat on the TERMPWR wire.
The SCSI bus must be terminated on both ends.
The SCSI bus uses an active low signal pulled high by the terminators using TERMPWR. A device asserts a 1 on a wire by pulling it to ground and then lets go (High-Z) and lets the terminators return it to 0 (Ideal: 2.85V, SCSI-2 minimum 2.0V).
The terminators are a lot more important than is immediately obvious as they determine the rise time of the signals on the bus.
There you go, more than you ever wanted to know about how to get the best performance out of your SCSI bus.
Keego
6,223
I have the cable that came with the card, it's pretty long but I don't have the drive plugged in at the end, it's about 1/2 way through the cable...
I have no other SCSI devices (nor plan to have any)
I bet I plugged it in the wrong port! Jeez :)
Keego
6,223
Wow, that fixed it, wrong port :eek:
That's what I get for switching it from one server to another w/o looking at the port labels!
