Hacp
So after getting some cash recently, I have decided that I want to build an HTPC. But I have NO idea how to build one, or what you need to do it! I have read online guides, but they don't go into much detail. I have a few genearl questions that I would like to have asked.
1) Video Card.
Is thing that connects the anolog signal to the TV the only thing you need? Can you tape Cable TV shows using only that connection? Thanks.
2) Recording
Besides WMCE, what programs are there that help in recording TV shows? Are there software applications preferably less than 50 dollars, that can update the TV schedules and record them before hand like TiVO? What format is the show generally recorded in?
3) HD space.
How much space does for example one 30 minute episode take?
I don't really care that much about Anolog versus Digital, as I'm not a sucker for quality much. Thanks for helping me! I'm pretty sure that a Basic PC would run in an HTPC pretty well. I'm thinking socket 754 with a Sempron/512MB of ram/ 2x 250GB hard drives.
1) Video Card.
2) Recording
3) HD space.
