General Low Performance
shamgar03
289
For some reason I am getting low frames in half-life 2 / DoD. So I ran aquamark and sure enough my scores were significantly lower than what I have gotten in the past. Here are my two scores: the first is 3 months ago, the second is today,
Processor:
Vendor: AuthenticAMD
Name: AMD Athlon(tm) 64 FX-53 Processor
SpeedMHz: 2403
Type: 0
Family: 15
Model: 7
Stepping: 2
Flags: 0xE1D3FBFF
Number: 1
HyperThreading: n/a
MemoryOS: 1072939008
Graphics:
Description: NVIDIA GeForce 6800 GT
Vendor: 4318
Device: 69
SubSys: 2739157058
Revision: 161
CoreClock: 5
MemoryClock: 9
Driver: nv4_disp.dll
DriverVersion: 6.14.10.7801
VideoMemory: 263192576
TextureMemory: 282066944
OperatingSystem:
Version: Microsoft Windows XP
Type:
Build: Service Pack 2 2600
Run0:
DisplayWidth: 1024
DisplayHeight: 768
DisplayDepth: 32
AntialiasingMode: 0
AntialiasingQuality: 0
AnisotropicFiltering: 4
DetailLevel: 4
AvgFPS: 63.639698
MinFPS: 24.630556
MaxFPS: 140.733383
AvgFPSRender: 94.645462
AvgFPSSimulation: 194.249466
AvgTrianglesPerSecond: 19157596
MinTrianglesPerSecond: 3106025
MaxTrianglesPerSecond: 39247798
AquamarkScoreRender: 9465
AquamarkScoreSimulation: 9713
AquamarkScore: 63639
That was good, this is the bad:
General:
Name: Benchmark 2006-07-21 07-32-26
Processor:
SpeedMHz: 2403
Type: 0
Family: 15
Model: 7
Stepping: 2
Flags: 0xE1D3FBFF
Number: 1
HyperThreading: n/a
MemoryOS: 2146680832
Graphics:
Vendor: 4318
Device: 69
SubSys: 2739157058
Revision: 161
CoreClock: 5
MemoryClock: 4
DriverVersion: 6.14.10.7772
TextureMemory: 513802240
OperatingSystem:
Type:
Run0:
DisplayWidth: 1024
DisplayHeight: 768
DisplayDepth: 32
AntialiasingMode: 0
DetailLevel: 4
AvgFPS: 27.844919
MinFPS: 7.525899
MaxFPS: 74.803238
AvgFPSRender: 40.635624
AvgFPSSimulation: 88.459740
AvgTrianglesPerSecond: 8382216
MinTrianglesPerSecond: 1590347
MaxTrianglesPerSecond: 13363603
AquamarkScoreRender: 4062
AquamarkScoreSimulation: 4422
AquamarkScore: 27844
My initial thought was cool and quite, which has caused trouble before, so I went and disabled it in the bios; no dice. I just reformatted my computer and went to 2 1gig sticks of ram the other day (from 2 512's). Windows is pretty freaken clean at this point. I initially used the latest (90 series) drivers but I thought that might be the problem so I removed them and then put on the 77 drivers, when that didn't fix it I deleted those, and used a driver cleaner and installed the 78.01 drivers (which you can see were the ones I used before). I will post my bios settings later, but any advice, experience or thoughts on the matter would be extremely helpfull because I am starting to run out of ideas (my last 2 are switch the ram back and change the bios settings around). I will post my bios settings later but I am running late for work. Thanks guys
shamgar03
289
One more thing: the front menu for my graphics card states:
Processor GeForce 6800 GT
Video BIOS version 5.40.02.15.01
IRQ: 16
Bus: PCI x0
Memory 256 MB
ForceWare version 78.01
TV Encoder Type: NVIDIA integrated
Does anyone know if it SHOULD say PCI x0 ? That seems wrong since mine is an agp card.
