General installation questions.
algae
916
Hi all,
I am reformatting a Win95 machine and at the same time am adding more RAM. Will it matter if I install the Ram first or the OS first?
Also, I am installing Office 2000 on the same machine. Does it matter if I install Outlook Express first? I am going to go to Outlook on this machine and use OE just for newsgroups.
Thanks for any info.
Gary
SonOfZeuz
549
I should not matter if you install the OS or RAM first.
don't know about your Outlook or OE problem as i don't and never will use them, too many secutity problems, OE is inferior to Forte Agent for newsgroups.
