1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
General work and light gaming PC.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
700 or less case and guts only
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
None
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Keys Mouse Monitor
7. IF YOU plan on overclocking or run the system at default speeds.
Default
8. What resolution will you be using?
1920x1080
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
Now
USA
None
Keys Mouse Monitor
Default
1920x1080
Now
