videobruce
I have had DSL for years and never had any experiance with cable modems. I have a few generic questions about them. The one in use is the Motorola SB5100 on what was Aldelphia, now Time Warner cable. There is also a Linksys router in the mix.
1. Adding a broadband amp (US made Winegard 40-1000MHz) seems to kill the modem. Is it because of excessive signal or is there a need for coverage below 40 MHz? Mind you, this isn't one of those cheap no-name Chineese made wonders. It is only a 10db gain, so I doubt it is a excessive signal issue. I would say there is around +5-10 dbmV of signal with the amp.
2. I was told (by TW support) that you have to leave the configuration of your NICs' to "Obtain a IP address automatically". Is this true? I perfer to assign each conputer with a static IP address. With DSL, I have no issue here, so I don't understand why cable would be different. What does the output of the router have to do with what the modem sees??
