I apologize for the length of this post. I've taken to the path of upgrading every few years with virtually a complete overhaul, as to not have to worry about parts for a while.
That being said, my last core upgrade was several years ago now, and this is what I've been running:
- INTEL BX80557E6600 Core 2 Duo E6600 2.40 GHz 1066 MHz Socket 775 4MB Processor
- OCZ Gold Series 4GB (4 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5400) CL 4-4-4-12 Dual Channel Kit Desktop Memory Model OCZ26672048ELGEGXT-K
- MSI 975X Platinum Motherboard
- eVGA Nvidia 7800GT (runs at 1280x1024)
- Kingston SSDNow 64GB SSD (boot, Windows 7)
- IBM 80GB IDE HD (OS backup, Windows XP)
- Samsung HD103SJ 1TB SATA HD
- ViewSonic VP930b 19" LCD
- SoundBlaster Audigy LS
- Antec True Power Trio TP3-650 650W ATX12V Power Supply
I design web and iPhone games as well as design user interfaces for PC games, so while I do a lot with gaming, I rarely need the top end specs, and for work purposes, am focused on small graphics and still frame rates. My PC work is primarily on MMORPG's that are designed for the masses, meaning you don't need a top end machine to run.
When I'm not working, I like to watch Netflix streams, play some SC2; and I'll definitely play Diablo 3 when it comes out. I'm in and out of Photoshop and Flash (CS4, but I should be getting CS5 soon). I really don't do anything else that would even begin to tax even my current system. Basically, the upgrade is primarily to ensure games run smoothly while still allowing me to work without being in any way impaired.
I know how to put the parts together, I know how to make the system work, but I don't know a lot about the individual components.
My ignorance...
I've been using this dual core Intel processor for years now, and I still don't understand the benefits (or detriments) to it. I thought the theory was to allow multiple tasks to run simultaneously, like Photoshop on one core and Flash on the other...or to allow some smarter programs to make use of multiple cores, like a game rendering the UI on one core and the level on another...am I even in the ballpark on this one?
- I know that most processors now are quad core; are programs and games making use of that now?
- I know this motherboard was 'forward compatible' to some extent, but I don't know if it would be good enough for current model processors.
- Am I correct in assuming that my processor would hold me back if I went with a higher end video card when talking about moderate/high settings on SC2 or D3? Or would a video card upgrade bring everything up to speed?
- I can't think of anything I do that runs more than 4gb of ram, or even gets close to 4gb really. Is the stuff I have compatible with newer boards or do I need to look at ram also?
- Is my power supply sufficient to run the newer components?
I don't like to do anything with overclocking as my machines all run all the time, and don't really think crossfire or sli would be something I'd want to mess with. My home office is upstairs and with multiple computers running, it gets pretty warm. My cooling isn't horrible, but is definitely not 100% optimal. Changing cases isn't currently an option based on where it fits though, so that is one limitation.
I'm budgeting probably around $300 for the processor, $100 for the motherboard, $300 for the video card, and I'm unsure on the ram or power supply. I'd like to spend under $1,000 in total, but I'm a bit flexible because I do want a system that I won't have to touch for another 3-5 years.
Thanks in advance, I really appreciate the input.
My ignorance...
