Discussion General ARM CPU/SoC news, rumour and discussion
Status
Not open for further replies.
soresu
This thread is for discussing everything ARM CPU/SoC related separate from the specific ARM Ltd Cortex and Neoverse CPU IP that this thread is dedicated to (though by all means discuss that here too 😄).
On the subject of nVidia's custom 'Olympus' CPU core:
@@ -0,0 +1,82 @@
+// REQUIRES: aarch64-registered-target
+// RUN: %clang --target=aarch64 --print-enabled-extensions -mcpu=olympus | FileCheck --strict-whitespace --implicit-check-not=FEAT_ %s
+// CHECK: Extensions enabled for the given AArch64 target
+// CHECK-EMPTY:
+// CHECK-NEXT: Architecture Feature(s) Description
+// CHECK-NEXT: FEAT_AES, FEAT_PMULL Enable AES support
+// CHECK-NEXT: FEAT_AMUv1 Enable Armv8.4-A Activity Monitors extension
+// CHECK-NEXT: FEAT_AMUv1p1 Enable Armv8.6-A Activity Monitors Virtualization support
+// CHECK-NEXT: FEAT_AdvSIMD Enable Advanced SIMD instructions
+// CHECK-NEXT: FEAT_BF16 Enable BFloat16 Extension
+// CHECK-NEXT: FEAT_BRBE Enable Branch Record Buffer Extension
+// CHECK-NEXT: FEAT_BTI Enable Branch Target Identification
+// CHECK-NEXT: FEAT_CCIDX Enable Armv8.3-A Extend of the CCSIDR number of sets
+// CHECK-NEXT: FEAT_CHK Enable Armv8.0-A Check Feature Status Extension
+// CHECK-NEXT: FEAT_CRC32 Enable Armv8.0-A CRC-32 checksum instructions
+// CHECK-NEXT: FEAT_CSV2_2 Enable architectural speculation restriction
+// CHECK-NEXT: FEAT_Crypto Enable cryptographic instructions
+// CHECK-NEXT: FEAT_DIT Enable Armv8.4-A Data Independent Timing instructions
+// CHECK-NEXT: FEAT_DPB Enable Armv8.2-A data Cache Clean to Point of Persistence
+// CHECK-NEXT: FEAT_DPB2 Enable Armv8.5-A Cache Clean to Point of Deep Persistence
+// CHECK-NEXT: FEAT_DotProd Enable dot product support
+// CHECK-NEXT: FEAT_ECV Enable enhanced counter virtualization extension
+// CHECK-NEXT: FEAT_ETE Enable Embedded Trace Extension
+// CHECK-NEXT: FEAT_FAMINMAX Enable FAMIN and FAMAX instructions
+// CHECK-NEXT: FEAT_FCMA Enable Armv8.3-A Floating-point complex number support
+// CHECK-NEXT: FEAT_FGT Enable fine grained virtualization traps extension
+// CHECK-NEXT: FEAT_FHM Enable FP16 FML instructions
+// CHECK-NEXT: FEAT_FP Enable Armv8.0-A Floating Point Extensions
+// CHECK-NEXT: FEAT_FP16 Enable half-precision floating-point data processing
+// CHECK-NEXT: FEAT_FP8 Enable FP8 instructions
+// CHECK-NEXT: FEAT_FP8DOT2 Enable FP8 2-way dot instructions
+// CHECK-NEXT: FEAT_FP8DOT4 Enable FP8 4-way dot instructions
+// CHECK-NEXT: FEAT_FP8FMA Enable Armv9.5-A FP8 multiply-add instructions
+// CHECK-NEXT: FEAT_FPAC Enable Armv8.3-A Pointer Authentication Faulting enhancement
+// CHECK-NEXT: FEAT_FRINTTS Enable FRInt[32|64][Z|X] instructions that round a floating-point number to an integer (in FP format) forcing it to fit into a 32- or 64-bit int
+// CHECK-NEXT: FEAT_FlagM Enable Armv8.4-A Flag Manipulation instructions
+// CHECK-NEXT: FEAT_FlagM2 Enable alternative NZCV format for floating point comparisons
+// CHECK-NEXT: FEAT_HCX Enable Armv8.7-A HCRX_EL2 system register
+// CHECK-NEXT: FEAT_I8MM Enable Matrix Multiply Int8 Extension
+// CHECK-NEXT: FEAT_JSCVT Enable Armv8.3-A JavaScript FP conversion instructions
+// CHECK-NEXT: FEAT_LOR Enable Armv8.1-A Limited Ordering Regions extension
+// CHECK-NEXT: FEAT_LRCPC Enable support for RCPC extension
+// CHECK-NEXT: FEAT_LRCPC2 Enable Armv8.4-A RCPC instructions with Immediate Offsets
+// CHECK-NEXT: FEAT_LS64, FEAT_LS64_V, FEAT_LS64_ACCDATA Enable Armv8.7-A LD64B/ST64B Accelerator Extension
+// CHECK-NEXT: FEAT_LSE Enable Armv8.1-A Large System Extension (LSE) atomic instructions
+// CHECK-NEXT: FEAT_LSE2 Enable Armv8.4-A Large System Extension 2 (LSE2) atomicity rules
+// CHECK-NEXT: FEAT_LUT Enable Lookup Table instructions
+// CHECK-NEXT: FEAT_MEC Enable Memory Encryption Contexts Extension
+// CHECK-NEXT: FEAT_MPAM Enable Armv8.4-A Memory system Partitioning and Monitoring extension
+// CHECK-NEXT: FEAT_MTE, FEAT_MTE2 Enable Memory Tagging Extension
+// CHECK-NEXT: FEAT_NV, FEAT_NV2 Enable Armv8.4-A Nested Virtualization Enchancement
+// CHECK-NEXT: FEAT_PAN Enable Armv8.1-A Privileged Access-Never extension
+// CHECK-NEXT: FEAT_PAN2 Enable Armv8.2-A PAN s1e1R and s1e1W Variants
+// CHECK-NEXT: FEAT_PAuth Enable Armv8.3-A Pointer Authentication extension
+// CHECK-NEXT: FEAT_PMUv3 Enable Armv8.0-A PMUv3 Performance Monitors extension
+// CHECK-NEXT: FEAT_RAS, FEAT_RASv1p1 Enable Armv8.0-A Reliability, Availability and Serviceability Extensions
+// CHECK-NEXT: FEAT_RDM Enable Armv8.1-A Rounding Double Multiply Add/Subtract instructions
+// CHECK-NEXT: FEAT_RME Enable Realm Management Extension
+// CHECK-NEXT: FEAT_RNG Enable Random Number generation instructions
+// CHECK-NEXT: FEAT_SB Enable Armv8.5-A Speculation Barrier
+// CHECK-NEXT: FEAT_SEL2 Enable Armv8.4-A Secure Exception Level 2 extension
+// CHECK-NEXT: FEAT_SHA1, FEAT_SHA256 Enable SHA1 and SHA256 support
+// CHECK-NEXT: FEAT_SHA3, FEAT_SHA512 Enable SHA512 and SHA3 support
+// CHECK-NEXT: FEAT_SM4, FEAT_SM3 Enable SM3 and SM4 support
+// CHECK-NEXT: FEAT_SPE Enable Statistical Profiling extension
+// CHECK-NEXT: FEAT_SPECRES Enable Armv8.5-A execution and data prediction invalidation instructions
+// CHECK-NEXT: FEAT_SPEv1p2 Enable extra register in the Statistical Profiling Extension
+// CHECK-NEXT: FEAT_SSBS, FEAT_SSBS2 Enable Speculative Store Bypass Safe bit
+// CHECK-NEXT: FEAT_SVE Enable Scalable Vector Extension (SVE) instructions
+// CHECK-NEXT: FEAT_SVE2 Enable Scalable Vector Extension 2 (SVE2) instructions
+// CHECK-NEXT: FEAT_SVE_AES, FEAT_SVE_PMULL128 Enable SVE AES and quadword SVE polynomial multiply instructions
+// CHECK-NEXT: FEAT_SVE_BitPerm Enable bit permutation SVE2 instructions
+// CHECK-NEXT: FEAT_SVE_SHA3 Enable SHA3 SVE2 instructions
+// CHECK-NEXT: FEAT_SVE_SM4 Enable SM4 SVE2 instructions
+// CHECK-NEXT: FEAT_TLBIOS, FEAT_TLBIRANGE Enable Armv8.4-A TLB Range and Maintenance instructions
+// CHECK-NEXT: FEAT_TRBE Enable Trace Buffer Extension
+// CHECK-NEXT: FEAT_TRF Enable Armv8.4-A Trace extension
+// CHECK-NEXT: FEAT_UAO Enable Armv8.2-A UAO PState
+// CHECK-NEXT: FEAT_VHE Enable Armv8.1-A Virtual Host extension
+// CHECK-NEXT: FEAT_WFxT Enable Armv8.7-A WFET and WFIT instruction
+// CHECK-NEXT: FEAT_XS Enable Armv8.7-A limited-TLB-maintenance instruction
At the very least it's got SVE2, though I don't see the SVE2_1 extension that would imply v9.4-A as a target.
Further investigation reveals the "HasV9_2aOps" flag which implies v9.2-A architecture profile as targeted by LLVM.
"Enable Armv8.4-A Large System Extension 2 (LSE2) atomicity rules" should make it better at binary translation for x86 -> ARM64 emulation a la Prism and FEXemu.
Status
