General 2-Fan PSU Question
Wierz
hello,
I have a general question about dual fan power supplies. If there is a fan located on the bottom, is it safe to assume that the air drawn from that power supply is being drawn into it from the bottom, and blown out by the second fan in the rear? They don't really say anywhere in the specs the direction of the air flow. I'm prompted to ask this because a) I've never owned a dual fan PSU before, and b) If the air is actually blow out through the bottom as well as out the back, it will cause an airflow conflict with my CPU heatsink/fans
any help is greatly appreciated, this is the PSU I was thinking of getting. Any feedback on it (or other PSU's) would be helpful as well. I don't 100% trust the reviews that are actually on the site of the product you're buying, ya know?
http://www.newegg.com/app/view...=17-153-007&DEPA=0
