- May 26, 2002
- 27
- 0
- 0
I have a Gainward Geforce4 Ti4600 and I am trying to set some shortcut keys to set the video out and resolution. I use to own a Asus Geforce card and Ctrl-t would switch the display to video out. Now setting the resolution wasn't an issue since it would automatically drop down to 800x600 when in tv-out mode. The problem here is I normally run in 1152x864, when I switch to nView "clone" mode it continues to run in 1152x864 on my monitor but it can only display 800x600 on my TV so it does the "extended desktop" thing and when I move to the edges it scrolls. This isn't what I want it to do, I need it to switch to 800x600 on both displays when I turn on nView, and I also need to be able to set a hotkey for this. The reason being I am using iRman and Girder to set up a remote and I need to be able to do this in simple keystrokes (1: switch to nview clone mode, and set resolution to 800x600) (2: turn off clone mode and set resolution back to 1152x864). I am sure there is a simple method to do this, but I can't for the life of me figure this out. Any help or possible solutions would be appreciated.
--Cyber-Psychosis--
--Cyber-Psychosis--
