Geforce4 Ti4600 Shows Up as 64 Megs?? WTF? Help!
Scroatdog
102
Hi. I recently swapped a Geforce4ti4600 from a Dell Dimension 8200 and put it in a Dell Dimension 8250. The 8250 had a 64 meg Geforce MX card in it. After the swapping of the video card, and some other things, XP was clean installed on the 8250. I have never seen anything like this before!!! SiSoft Sandra, 3dMark2001, and the adapter properties in XP all report the car as 64 megs!!!!! But when I bench it in 3dMark, I get scores over 13,000 with no overclock.
Has anyone seen this before or know how to correct this??
Thanks
BFG10K
22,709
3,007
This problem is usually caused by overclocking something in the system. Also make sure that you have the latest BIOS and chipset drivers for your system.
