Geforce4 MX 440 or radeon 9200
The Green Bean
ehich one is better???....Also i have herd that Geforce has stopped supporting 4x AGP which my motherboard uses?
So which one should i get the Geforce is a bit cheaper
9200 is an 8X 9000 non pro, which is slightly slower then an mx460, but a good deal faster then an mx440, the 9200 also has dx 8.1 support, which means it will be faster in games of the future, such as halo for pc, and dx8 games now, and half life 2 will use all those cool dx8 features, which non of the mx series has.
I jus tried simcity4 on the radeon 9200 the scrolling SUX....IT works better on the bilt in viseo (intel)....DO u think it will work better if i uninstall and reinstall???
Also will the 9200 work games like cnc generals ETC?
thanx hatim
thanx hatim
Hmm that scrolling thing might be a driver bug; try the newest Catalyst and see if it helps
and yes 9200 will work with C&C Generals; even my old GF2MX/MX worked with C&C Generals
Also, My mohterboard supports only 4X not 8X.... Will that make a lot of differnce.....
I also have another choice radeon 9000pro but only 64MB memory....
So u think i shud stick with the radeon 9200
I dont have the latest drivers or DX9....Ill install both and see if i get that scrolling problem.....otherwise ill got with the MX which seems to be running smoothly with generals.....
But i think u donot get 4X agp support now from geforce4?
thax for all the hellp
hatim
hatim
Well of course it's running faster - it has drivers.
Go get the Cat 3.6's and DX9 and report back.
- M4H
a 9000 pro is miles faster then a 9200 or 9000 standard. If you can get one for the same price go for it, 64Mb 9000 pro would flatten a 128MB 9000. But i got best of obth worlds 128MB 9000 pro!
