Geforce2 Pro Problems!!!
Silverdream
4
Hi,
I am currently having a problem with maxpayne. When i start the game it works fine and then freezes. There is colorfull stripes on the screen and the system locks up. I have to reset the system. It happens in maxpayne and quake3 and 3dmark2000. However 3dmark 2001 & UT works fine. I am unable to figure out the problem. I have tried reinstalling the OS several time but still no use. I use the latest drivers. My system config is as follows:
Amd Duron 900
256mb pc180 ram(OCZ)
Asus A7v133-c
Leadtek Geforce2 Pro(200/400)
SBLive Value
Adaptec 2940UW Pro
Realtek 10/100
TvTuner(BrookTree Chipset)
IBM Deskstar (30gb)
Seagate Baracudda ATA III (30gb)
Pioneer 16x DVD(Slot)
Plextor(4/2/20)
300PSU(Aopen)
Swiftech MC462A
OS: Win98SE
Any kind of help will be appreciated.
Amused
57,413
19,804
The colorfull stripes sounds like a vid card memory problem. Is your card over-clocked? [edit]oops, I just saw that your card isn't overclocked :eek:[/edit] I get that same thing if I push the memory clock speed too high on my GF2 Pro.
If your card is not over-clocked, pull it and make sure there isn't dust caked on the board around the chips.
I was getting some psychedelic light shows on my old Voodoo2s a few years ago when playing games. I pulled the cards, cleaned the dust caked around the chips, and the cards worked fine again.
If this isn't it, try an earlier driver version, or the reference drivers if using the manufacturer's drivers, and vice-versa.
