GeForce2 MX400 Installation Help!
SugarPatcher
Any ideas on installation problem of GeForce2 MX400?
I need some help please! I bought this new card made by PNY - Verto GeForce 2, MX400, 64 mb AGP card....nvidia chipset
What I have now (and all is working A-OK, all Direct draw tests and 3D tests check out successful with DXdiag.exe):
Athlon 650 - not overclocked at this time
Asus MB K7M
300 watt power supply (supplied by Multiwave, supposedly approved for use with Athlons)
768 mb SDram, PC133/cas 2 (Crucial - 3 DIMMs 256mb each)
SB Live soundcard ( current drivers)
Nvidia TnT2 Ultra video, 32 mb ram (Diamond card but running reference Detonator drivers 21.83 - 23.11 cause freezing on my system - tried several times with them and had to revert)
DX 8.1
Win98 SE - all Windows updates are current
2 Maxtor hard drives at Ata 66
52X CD
HP-9100 CDR
Std floppy
US Robotics PCI Gaming Modem
10/100 NIC
All AMD drivers and Via drivers are updated also this week
(Northbridge = AMD 751, Southbridge = VIA VT82C686A)
This MB supports AGP 1X and 2X
I can not install the GeForce2 card! Every time, it goes to set up the drivers ( I start with std VGA drivers as advised.) after detecting new hardware, and installing drivers, it reboots Windows then....I get this god awful screeching sound, a blue screen flashing and I have to shut down, go back in via safe mode and re-set to std VGA drivers again. I tried installing the drivers on the CD that came with the card and the reference drivers I have here also. No go. I double checked things in bios that were listed on the troubleshooting Help for the card, and can't see anything wrong there ( aperture size, etc.). I am stumped here. Do you think this card is bad? Isn't compatible with my MB? It's supposed to work with k62 and up, 64 mb ram and up, AGP1x and up...
I re-installed my old video card (TnT2 Ultra), and set up the reference drivers again, and it's smooth as silk. So I know I'm installing drivers correctly....sigh. I checked and no IRQ conflicts...only share that with the PCI steering holder as advised. It's in slot 2 because 1 and 5 share same IRQ as the AGP slot, working fine with the old Nvidia card.
Any ideas or where I can go look? I didn't have any luck on PNY website or Nvidia so far. At least I don't know what to check first.
I NEED to have GeForce2 minimum card running here to use the new expansion of Everquest (online 3D game).
I have several fans in this case, including a drive bay fan, slot exhaust fan, front fan...so I don't think heat is a problem, anyway this never gets started up to even get warm!
Any help is appreciated here.
DIRTsquirt
424
I feel your pain. I had couldnt use the drivers that came in the box with my geforce gts either... kinda funny if you think about it. new card open box insert card install drivers....all kinds of funky stuff ensues.. I ended up getting the detonator drivers and all has been well.. almost 2years now.... :)
I would get the latest detonators drivers from nvidia.
Are you running the latest 4in1 drivers?
IgorTs
421
try on different comp. Card can be defective, also they just reliased new drivers, try it too
