Geforce2 MX TwinView and AIW Rage Pro 128 in triple monitors
MrDudeMan
15,069
94
is there anything i need to know to make this work in windows xp? maybe this is in the wrong forum...
will these video cards work in MMS? if so, will i be able to get 3 monitors working?
any ideas? thanks!
powerMarkymark
2,164
Assuming that your GeForce is AGP and your ATI AIW is PCI, it might work.
Don't know if your Twinview card will allow another PCI GPU at the same time. I say this because ATI Dualhead cards don't allow another GPu at the same time. You may want to check that out on their FAQ sheet.
Don't forget, in order for the ATI AIW multimedia properties to function, it must be set as the primary GPU in the BIOS.
Please post if/when you try the configuration.
MrDudeMan
15,069
94
thanks for the tips, ill post tomorrow evening when i get a chance to try it out
