faster then a voodoo 3? No way. I just got my ocie.com OEM version of the Toronoda Geforce 2 mx 32 megs of 6 nano second samsung ram, w/heatsink and fan ( I didn't order the fan But they sent me one anyway
Anyway I had a Voodoo3 3000 in my system it is faster then a geforce 2 mx but, the image quality is far superior on the gforce mx. 32 bit color, full scale antialiasing, T&L on the card, etc, etc, etc.
The difference at 16 bit color, normal settings,640x480x16 quake 3 demo2 is the geforce about 75 frames per second and the v3 3000 about 90-95 frames per second with a 840 MHz celeron 2 ( 533@840 )........Now at 1024 x 768 on a 17 inch monitor in 32 bit color 32 bit textures everything on high, quake 3 is still playable..... and it looks like I never new it could!!!!!!!!!! awsome baby!
Now If I could only figure out why I cant over clock it. the default settings are 175 core and 166 memory on my card. If I try to turn the core up even 5 MHz it locks in the quake 3 setup screen.......If I leave the copre alone and try to overclck the memory by as little as 7 MHz it locks in quake 3 setup screen... I have a feeling its 6.18 driver I am using that everybody seems to have some kind of trouble with.......i just found the newer detonator and I am going to try it now.......Il let you know if I can overclock with this driver.
I really need to get some more out of this card, I heard it was easy to over clock, and get almost Geforce2 ddr performance at the lower resolutions. well see.....
