In my quest for a fanless GeForce4, I found this Xbitlabs review which explains how to modify GeForce4 voltage. Here is a detailed diagram of how their mod works.
I'm trying to do the opposite: decrease voltage. The voltage was equal to 1.25V * (1+R12/1) where R12 and R1 were Ohm values of the corresponding resistors. They increased voltage by shunting the R1 resistor, because it increased the (1+R12/R1) ratio. To decrease it, I understand you would shunt the R12 resistor instead, which decreases the (1+R12/R1) ratio.
In my case, the SC1102CS voltage controller is used on my Gainward ti4200, and here is the diagram for it. Now the ratio is (1+R8/R7) and I need to shunt R8 to reduce this ratio & undervolt the card.
(edited: )
So it appears I should connect a resistor between Pin 11 and some other place in order to shunt R8. But, where should the other end of the resistor connect? Here is a photo of my card; the voltage regulator is the large chip in the lower center. Pin 11 is the center-right pin, but where in the world is R8 or the 2.5V line?
Your input would be greatly appreciated! Once I get this working I'll report on my results 🙂
(edited: )
