- Dec 17, 2000
- 510
- 0
- 0
Hi , this morning i upgraded my old Geforce Mx with an used Inno3D Geforce 2 Pro 64 Meg 5Ns .
Now i installed the new 12.90 Detonators ( 100% Complete clean of old drivers in Safe mode with Add-remove-Programs helped also with NvCleaner & Detonator Destroyer ) but in my Display Properties / Geforce2 GTS the memory is reconized as 32 Meg and not the 64 Meg i hawe ; SiSi Sandra also see 32 Meg and 3Dmark2000 also.
When i pass the 3Dmark 2000 the test 64 Meg Texture Rendering 1 times from 3 it will freeze and the in the running time of this particular test the Videocard hawe extreme slowdown's and small lockups.
Also the 3Dmark 2000 give me only 5800 !!! Score wich is exact the same like my old overclocked Geforce Mx ( 5927 Score) .
I changed in Bios the Agp Aperture to 128 and also 256 but i hawe the same results ;..the rest of the setings in Bios are set in conformity with NVidia requests .
How can i see if all the 64 Meg work ? and why i hawe such a low 3Dmark score ....
This Card hawe an Extreme Cooling Kit applied to GPU and Memory ;... i heard also in Sharky about 2 people who lust 32 DDR of 64 2-3 weeks after installing such Kit to an Ultra (one of them is FaTs the Moderator), so i hope very strong to not be that.
Therre is in Bios something sould i enable for this 64 Meg ?
I hawe a P3B-F Asus / P III 933 EB / 256 Mushkin Rev2 .
I will go this afternoon to buy a New Be6-2 and test to see ;....may be this videocard does not like the P3B-F (wich i also don't like too much)
Thank You.
Thank You.
