GeForce GTX 480 liquid cooling Danger Den review
lsv
1,610
Seems like a waste, the air cooled 5870 still keeps up with it =/
Axon
2,541
Impressive. But considering what you'd have to pay for that block and the card itself, I don't know if it's a better price/performance option than the 5970. However, I'd also like to see a comparably overclocked and water cooled 5870, which I believe would be the most accurate comparison between both companies single GPU offerings.
Why the Fermi has been so controversial is beyond me. It is clearly an excellent card. My only concern would be heat in an SLI situation, which I likely would never want to pay for. I'm sure most users would be fine with a single 480 GPU.
Skurge
5,195
a shame they only tested 2 games and one of them being MW2 (ugh) against a stock 5870.
I don't think it will keep up with a 5970 though, it gets about 60fps in BC2
thilanliyan
12,065
2,278
"Things are going really sour for BFG Technology though, do not expect them to release a GTX 480 with pre-fitted liquid cooling solution whatsoever, in fact I'm not even sure if BFG-Tech will last through this year as the economy hit them real hard."
That's not good.
Sylvanas
3,752
That's some sick clocks and temps. However, it won't convince me that Fermi is a good buy- just not enough reason to over the competition, I'll be waiting for next gen. Best thing these days is both Nvidia and ATI finally realised that we wanted adjustable voltage control on cards for OCing purposes, makes life much easier without hardmods.
Qbah
3,754
10
Wow! That's almost a 30% overclock! And 59C in Furmark :D Amazing setup :) Not to mention the results are awesome - that's almost linear scaling O_O Looks like the architecture is amazing :)
EarthwormJim
3,239
I want to see reviews of the GTX 470 on water. I'd like to see how high it can overclock.
RussianSensation
19,458
765
You mean 5970 right? It destroys a 5870.
? I wouldn't use the word "destroys" when we are talking about a product that will cost $200+ more.
BF:BC2 2560x1600 (most stressful on the graphics card)
GTX480 @ 900 gpu = 45 fps (+25%)
5870 stock = 36 fps
Modern Warfare 2 2560x1600
GTX480 @ 900 gpu = 116 fps (+29%)
5870 stock = 90 fps
GTX 480 ~ $510 + $135 for the copper block = $645 (+57%)
vs.
5870 is ~ $410 with shipping at newegg
So 57% more expensive for 25-30% faster performance. Of course you can overclock the air cooled 5870 as well. Seems like bad value to me (of course high end is never about "value"). I would much rather get GTX 470 SLI for $700 (those run cooler than GTX480s) and scale better than 5870s in CF.
MagickMan
7,460
Finally! This is what the 480 was supposed to be. Too bad you need a $300 WC setup to realize it.
happy medium
14,387
480
SolMiester
5,330
17
5870 stock = 36 fps
5870 stock = 90 fps
vs.
Why does value always come in to it? You pay for the best, Ferrari isnt the value compared to whatever else powerful car, but thats not the point is it! Why supercharge or Nitro a car?....Its only about performance!, you want bang for buck get a ricer etc!
Sylvanas
3,752
If you're going to use that argument you might aswell say everyone go and get a 5970 as it is the fastest and most expensive card out regardless.
SolMiester
5,330
17
But we are not talking about the 5970....apart from the fact tessellation hurts the 5970 anyway!
SolMiester
5,330
17
MagickMan
7,460
What doesn't work that way, a fair race?...You don't compare single core CPU's against dual or quad cores do you even though they all use the one socket?!
Actually, we do compare all CPUs, regardless of # of cores. :hmm: Nothing in life is fair.
the 480 isn't a good value, and it isn't the fastest single card, or multi-card setup either. So far, the only good value is a 470 and OC the hell out of it and hope it doesn't melt (and your ears don't bleed).
SSChevy2001
774
There's plenty of review sites that's compared different core CPUs.
http://www.anandtech.com/show/3674/amds-sixcore-phenom-ii-x6-1090t-1055t-reviewed/9
What's not fair about comparing 1 GPUs against 2 GPUs, when in the end those 2 GPUs are consuming less power? Not to mention that Nvidia GPU's is 60% larger.
SolMiester
5,330
17
]Actually, we do compare all CPUs[/B], regardless of # of cores. :hmm: Nothing in life is fair.
What?...if you were comparing CPU between Intel and AMD, are you trying to tell me you would compare 3.2Ghz single core against AMD 3.2Ghz Dual core and call it a fair comparison?
LOL, I dont think so!
SolMiester
5,330
17
MISSING the point...hello, apples and oranges!....CPU die has also differed..If you dont get okay, I cant be bothered, but you cant tell me a dual GPU is a fair comparison against a single GPU!
edit - guess i better state i am talking architecture or IPC
