I bought an FX5700 ultra 128Mb about 6 weeks ago. The proper default clock speeds are 475MHz Core and 906MHz Memory. The thing was fine (I think) until last night. The card is overclocked, but by no more than 10% which to my knowledge was well within safe limits, I did it gradually and everything.
Last night though I noticed Riva Tuner was reporting 300MHz core in the 'real clock speed' box or whatever it is, the one below the number you adjust in drive level overclocking. So i check AIDA, and sure enough its saying the GPU core is 301Mhz, far below the 475Mhz its supposed to be. If I change the core speed in Riva Tuner or set to defaults, it shows the correct values again, but then goes back to 300MHz a few minutes later.
Does anyone know whats going on? Have I screwed up my card or what? I have a 350W PSU, a thing of note is that I used to have a USB lamp and it used to flicker quite a lot and especially when taxing operations e.g playing games were being carried out. Is it possible that the lower core speed is because of a lack of sufficient power?
Thanks in advance.
Thanks in advance.
