GeForce 9800 GTX+ / GeForce GTS 250
bloodandsoil
What EXACTLY is the difference between the GeForce 9800 GTX+ and the GeForce GTS 250 (other than the name or price)?
error8
3,204
Usually GTS 250 comes with 1 gb of vram (but there should be 512 mb variants as well) , has lower power consumption and a different PCB. Other then that, they're the same.
Soulkeeper
6,731
155
the gts250 board is supposed to be 1" shorter
not all manufacturers followed this though, zotac and others have the longer design just relabeled
josh6079
3,261
9800 GTX+ vs. GTS 250 512MB - Absolutely no difference in build or performance. Different sticker, that's all.
9800 GTX+ vs. GTS 250 1GB - Shorter pcb, lower power consumption, and more VRAM.
zerocool84
36,041
472
No only the 1GB version is shorter and uses the new PCB. The 512 is the same.
Zap
22,377
The shorter PCB and lowered power requirements were implemented late in the life of the 9800 GTX+ so there's some overlap. I think perhaps NVIDIA was originally going to "save" the new design for the GTS 250, but implemented it early as a cost saving measure as prices decayed.
Soulkeeper
6,731
155
nope, check newegg
some of the 512's were shortened as well. completely up to the manufacturer
SlowSpyder
17,305
1,002
Example of what you said.
Yea, some 9800GTX+ cards have 1GB, use a single 6-pin power plug, and have the shorter PCB making them essentially identical in every way to a GTS250. It's really just a question of which sticker the manufacturer wants to put on the card.
