geforce 7800gtx vista problems
nomadicdude
I installed nvidia's 96.85 drivers and it doesn't seem to be working. Nvidia's install finishes without complaing. But immediately after it finishes vista complains that the driver didn't install correctly. I see the following in the properties for the device driver:
This device cannot find enough free resources that it can use. (Code 12)
If you want to use this device, you will need to disable one of the other devices on this system.
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
Any suggestions on how to troubleshoot?
Thanks.
