geforce 4400ti cooler
kd2777
1,336
Can anyone recomend a good aftermarketone? My stockone laid down and DIED!!!
Thanks
KD
Nickel020
753
There's one from Thermaltake which looks identical to the reference hsfs but is made of copper. Should be about $10. You can also get a passive heatpipe cooler (Aerocool VM-101 or Zalman ZM-80) and if you have a good case airflow you should be able to overclock with it. For the Zalman you can also get the OP-1 fan to mount at the side to get better than stock cooling.
L00PY
1,101
I'm in a similar boat (Ti4400 with fan being the noisiest thing in my rig) and while I've considered getting a heatpipe cooler, I've decided to go another route. The cheapest I could find a ZM-80D was around $40 shipped. Instead of spending my money on that, I figure I'll credit that towards say a 9600 XT from Newegg, and I'm only paying $100 to upgrade my Ti4400 to a DX9 card. (Yes, that's somewhat fuzzy math -- but in the end it all balances out.)
