geforce 4 question (screenshots inside)
Raspewtin
3,634
This link will take you to some screenshots of some water effects done on GF4 in the upcoming RPG Morrowind. My question is will the visual quality in games be appreciably different with GF4 then GF3? I mean would water look just as good with a GF3? The reason I am asking is b/c I do not care much for speed but I care a lot about visual quality and was wondering if there will be a visual quality difference in the 2. I understand the specs, the new vertex shader, etc in GF4. Thanks a lot for reading this dumb question and thanks in advance for those who answer.
Leon
2,215
4
At similar resolution/color depth, image quality will be the same. However, with GF4, you can turn 2x/Quincunx AA, and still get a speed of GF3.
