Geforce 3 Ti200 Problems
jkj
Ive got an geforce3 ti200 and im only getting like 30 frames in unreal. I dont think tis the rest of the system what could be wrong? AGP settings? Ive already upgraded drivers to the latest detonater xps. I have 512mb of ddr. The system is a 1800+ running on an epox 8kha+. Anything?
First of all, are you talking about Unreal, or Unreal Tournament?
For Unreal make sure your running in D3D. For UT, follow the instructions on how to install the special Loki OpenGL DLL here
Thanks a lot that solved my problem, but I have one more... I can't figure out why I am now peaked out at 75 fps and I mean exactly 75. In my display settings I have it set to always turn vsync off but it appears that it is using it anyway. How do I check in UT to see if it using it?
I just typed in preferences and looked for vsync in video and it says its set to false but I continue to get exactly 75 frames. What is up?
One more odd thing is that when I run it a window my fps run to upwards of 200 frames. Even if the window is almost full screen.
