Ok, I jumped on the wagon and got the Geforce3 Ti200 at BB.
Problem is, I can't get it to work on my comp! I'm no hardware dummy, i've installed dozens of cards before, this one has me stumped.
Inserted Card, Booted.. Computer hangs mid-boot.
reboot.
Computer hangs at network login screen.
reboot.
Boots ok. Install Geforce3 Ti200 drivers found in Win98-ME dir, i believe it's Nvagp.inf
Reboot.
Now it's freezing about every other boot. When it does boot, it's in 640x480/16 colors.. default VGA settings
everything looks ok, i guess, not including the crappy res and freezing. But as soon as I try to increase either resolution or color, comp freezes, reverts back to default VGA.
I guess couple things to be of concern. Manual says no sharing of iq ports, modem is shared on port 11, but i can't change it. (won't let me)
EDIT: tried with no other PCI slot's in use. that's not it.
Also last time i tried to install Geforce 2 GTS, never got that to work properly either, it ran choppy, had to return, but that was an older mobo.
Anyone else have insight/advice?
install via 4-in-1 again after install? detonator drivers? i'm stumped.
System Specs:
PIII 667 /w 256 MB RAM
Win 98 SE
Tyan S1854 Trinity 400 Mobo (recently purchased)
Thanks!
paulee
reboot.
reboot.
Reboot.
System Specs:
Win 98 SE
Thanks!
paulee
