GeForce 3 Ti 500 and Dual monitor Support
Artician
Hi.
I need to know if the GF 3 Ti 500 properly supports dual monitors. I have a 21 inch Sony CRT hooked to the standard CRT out, and a 19 inch Sony CRT hooked to the DVI out (using the DVI to CRT adapter).
When I turn everything on the monitors display in mirrored mode (both monitors display images of the same desktop with same cursor movement, etc.) but they are very dim. Also, windows does not detect the setup as dual monitor, so there is no way to configure each monitor in the Display Settings or using nVidias nView software.
I've tried everything, so please tell me if this just does not work with this video card.
Many thanks in advance!
