Geforce 3 problems, maybe?
Last night I bought a whole new setup. This is what it consists of:
AMD Athlon T-Bird 1 GHZ 266 FSB
Abit KG7-Raid
256 2100 or whatever number DDR Ram
Visiontek Geforce 3
SB Live X-Gamer
IBM 60GXP HDD
Well sometimes I can see these little like artifacts or something of the like. And I just got threw a game of UT and when I throw a bomb with my missle launcher I can see this green like dots that floats up after I throw a bomb. I don't know whether that is correct or not, please correct me if I am wrong. But also when I go to my start menu and I look through it on the screen after the start menu's gone away it'll have like three artifacts on the screen. I'll try and take a screen shot, maybe it will come out. But the artifacts are just lines and when I click on the return to desktop icon in the quicktray those lines go away.
What could be wrong??
I'm also running WinXP RC1. Thanks for your help!
[*]Are you o/c'ing?
[*]Have you tried different 4-in-1's?
[*]Have you tried the 21.81 detonators?
Actually, the Abit KG7 uses the AMD 761 chipset, so you shouldn't be installing the VIA 4-in-1 drivers. I believe there's an AGP patch for the AMD chipset, but I can't remember what it's called. Someone else should be able to point you in the right direction. As for the Detonator 21.81s, look here
The KG7 is a hybrid AMD761/VIA 686B
With that in mind you install the AMD agp miniport but I am not sure about one for XP since it might have a native one, or the one for win 2K might work in XP. Also, you install the 4-in-1's and uncheck the agp driver during setup.
