Geforce 220 / Resolution Reset
hkleo_Da
I installed a new graphics card, Nvidia Geforce 220, running Windows XP
On the 1st boot up, it started at 480x640, then i install the driver (up to date), restart, normal resolutions and works great.
Then when I restart it (2nd boot up), it goes back to 480x640, 32bit. It gives me the option to reset the resolution/color bit mode, but no matter what I select it just reverts back to 480x640/32bit color.
If i uninstall the drivers, reinstall, reboot, it works again, but upon the reboot right after it works, it goes back to 480x640.
Anybody have a clue where the root of the problem might be? Should I try an older driver?
*I'm installing the drivers with no user to choose, so I'm assuming I'm doing w/ admin rights.
*Drivers I got are off Nividia website
