Geforce 2 tv out issues
illbot
40
Anyone have your geforce 2's conected to your tv via svideo? how come i can keep my monitor at a decent res with twinview on and what are those ugly lines going upwards in the background of the tv image ?
am i doing something wrong?
TonyT
309
I have had the Geforce 2 connected to my tv via s-video, and have never experienced the problem you described. Make sure you are running the card at one of the "officially" supported resolutions (640x480 or 800x600). Other than that, you could try turning hardware acceleration down in the control panel; perhaps that's causing the problem on your tv screen.
illbot
40
running it at 8x6
i think they're called scanlines
i'll give it a try tonite
thanks
