GeForce 2 Pro Fan advise...
riddelrp
554
I have had a GeForce 2 Pro in my system for a year now. For me the card is all I need. Just a few weeks ago the fan started making a bunch of noise.
To me it sounds like the fan is off balance. It almost sounds like a real thin wire is hitting the fan, but I checked it and no wires are in the fans way...
Is it possible to buy a new fan for a GF2 Pro? Where would I find one?
Thanks,
Ryan
Zugzwang152
12,134
Sure you can, take it off and measure it, then check out shops for a fan that is the same size. If its a standard size, then you can probalby use the screws from the old fan to put up the new one.
