Which card do you suppose is more capapable. A Geforce2 gts (ihave the slighty cheaper underclocked "-v" model with slower mem than the regular gts) running via AGP or a MX440 running on a PCI port.
I have a 1.13 thunderbird with 300+ odd megs of ddr ram and I plan on running a 3 monior setup (well realy 2 mon. and a TV) and want to know which card I should set up to use the middle monitor. Of course I would like the speediest/best quality on my main screen.
I know that the MX 440 is a slighty more capable card.... but how much of a choke is the PCI slot? I know that back with the original geforce cards when AGP cards were competing directly with PCI cards that the AGP slot realy didn't provide much of a performance advantage, but I am sure that 2 geforce2 cards (hehe geforce "4" mx440 my #$%) use quite a bit more of the bus bandwidth... but then again I am running a 133mhz bus. So in my mind the MX440 would be the slighty better card when all things add up......
On my computer is the PCI bus still restricted to 66 mhz? (for backward compatability) Or has the PCI bus kept up with the increases in technology.
(I remember back (seems like ancient history) when I overclocked my 233 mmx using a lower (3x) multipler and a increase bus speed of 83mhz (250 mhz WHOOHO!) it did make a bigger increase in performance than keeping the bus at 66 and running the multiplier at 4 (for a grand total of 264MHZ!!!!!!) (man my quake 1 performance rocked up to almost 56 fps on demo 1 !))
Is this still true?
Is this still true?
