Geforce 2 GTS and UT problem!
JokerF15
1,464
hi..
for some reason, when i use my Elsa Gladiac Geforce 2 GTS i cannot run UT. I can run it in safe mode, do i need do dl any other drivers. i have the latested update. every other game i have tried works including q3a, madden 2001, nhl 2k, nba 2k, mlb 2k, The Sims, Sims Living large, Diablo 2, etc...the only game that doesn't work is UT and i really like it. My sys is in my sig.
andylawcc
18,183
UT is very sensitive to Ocing.... that's all I could say.
and use Direct3d instead of Opengl, just in case you did.
Bad Dude
8,464
Go back to the Detonator 2 drivers. It might be the new Detonator 3 drivers problem.
Wah
1,799
drop your CPU speed a little a see if that helps. when i overclock a bit too much i get all these weird errors with UT.
ColdTech
225
Also Make sure you dont have Dx7a... I Had the same problem severail times... It took me 3 weeks & severail formats to figure it out because I had the same problem
