GeCube X1950PRO 680/1620!
Paratus
Check it out:
Link
Pic
GeCube Sets World First -- TEC Cooling Chip for FZ Cool Radeon 1950PRO Graphics Card Limited Edition - An Overclocker?s Dream for Super Cool and Super Overclocking !! 2006-10-17
Taipei, Oct. 18 2006 -- The world-renowned graphics card brand GeCube announced the arrival of the FZ (Freezer) Cool overclocked ATI RADEON 1950PRO graphics card with thermoelectric cooling system. With the heat dissipation significantly boosted to offer superb cool overclockability, this limited edition card is now being launched world-wide for the super gamers.
GeCube?s FZ Cool graphics card takes cooling solutions for X1950PRO overclocking to the next level by being the first graphics card in the world to incorporate a TEC (Thermo Electric Chip). TEC?s superior cooling performance means that even when the FZ Cool is overclocked to the highest limitation, by 20% the temperature remains within the optimum 60°C ~65°C range providing the high ASIC life cycle in overclocked status. The FZ Cool also stands out in 3D Mark 05/06 benchmarks by outperforming standard versions by 15% and returning the best scores as well. The FZ Cooling system has Quad heat pipes and twin 8cm silent fans with automatic speed adjustment, special overclocking temperature control function and recovery mechanism. This ensures that overclocking will no longer shorten the life of your graphics card! With its class-leading ultra-cooling design and perfect visual effects, the FZ Cool is the dream card for master overclockers for super cool and super overclock at best budget affordable !
In addition to the FZ Cool equipped with TEC chip and FZ double-fans, 1950PRO series cards equipped with normal cooling fans are now also available for power users. All three products use the ATI RV570 core manufactured using an 80nm process with onboard GDDR3 512MB/256MB high speed memory. HDCP is also supported to provide you with the ultimate audio-visual experience.
The 1950PRO series of products support Shader Model 3.0, use the latest graphics processing architecture, produce the highest frame rates in the industry and comes with 36 pixel pipelines to provide the fastest graphics processing capability. For HDTV digital output support, Dual DVI (2 Dual Link) offers display resolutions that far surpass other products in its class. It aslo supports Windows Vista ready so you can easily upgrade your system when it is launched. The hardware supports the CrossFire platform enabling two cards to operate in parallel. The result is the most vivid and photo realistic images even at high resolutions, with the high performance architecture providing AFR, Supertiling, Scissor and SuperAA Rendering modes for superb graphical quality. The dual card setup also allows 12x Multi Sampling AA to be turned on concurrently with 2x Super Sampling AA to achieve a staggering 14x AA. This means that the visual quality is enhanced even further without impacting on system performance, so that even as players enjoy the detailed high-resolution graphics they can also expect the best in gaming performance.
Pretty damn nice for a factory ATI card :Q
We need ATI Tool to be updated to see just how far that 80nm core can go. But 105mhz isn't a bad start. 😛
posted via Palm Life Drive
Thats the new rev 2 X1900GT.
X1950PRO is 575/1380.
Rev 1 X1900GT was 575/1200 IIRC
