B Boo025 Member Oct 6, 2006 79 0 66 Dec 19, 2007 #1 Just wondering is it possible to play GOW co-op on LAN with one copy of the game?
B BladeVenom Lifer Jun 2, 2005 13,365 16 0 Dec 19, 2007 #3 I think so. Most games you only need the disk at start up. After that you can take the disk out and use it to start the game on your second computer.
M MrWizzard Platinum Member Mar 24, 2002 2,493 0 71 Dec 19, 2007 #4 Maybe yes maybe no. Try it and find out, although if it uses a CD key depending on the company sometimes the block the same CD key from connecting to a lan/WAN game.
T tvdang7 Platinum Member Jun 4, 2005 2,242 5 81 Dec 19, 2007 #5 i just did last night with my friend. you have toinstall a GOW hamachi fix. then it works forgot where the website is here we go get a cd fix from game copy world. and use this fix to play on lan. http://hamachigow.blogspot.com/ have fun.
